Programming help.
I am a student who is invovled with ballon satellite project sponspered by NAU and Nasa.
We are sending up a package that will take pictures and collect certain data way up high, however high weather ballons go up.
We bought a BASIC stamp, a few of the courses, and a accelerometer.
I am currently trying to program the accelerometer and the BASIC stamp to log data throughout the trip, which is about 2 hours long If I recall correctly. Therein lies the problem, I simply dont know how to program and am looking for some quick suggestions. Sadly enough, the launch is coming up real fast.
So far, I am trying to tweak the program, MEMSIC2125-Dual.BS2, to Write the approprite data thoughout the trip. I didnt think it whould be that hard, but it seems so.
I could use some guidance.
Sean
Post Edited (cannibalmonk) : 4/17/2006 5:56:07 AM GMT
Sean
I have six varibles that I want to WRITE, every second or minute, or as many crammed into an hour that I can. Then I want to read them at a latter date.
So they are stored in the EEPROM forever until I READ them with a seperate program or until I write over them, right?
Any help whould be greatly appreciated.
- You re-program the stamp.
- You write to the same Eeprom location too many times, (the limit I think is around 1,000,000 writes to the one location, search this forum to be sure). So if you write to the location·a few times per second, the life of the stamp is going to be fairly short. If you only write to the location say, once an hour,·then you wont have any problems for a very long time.
If you 'put' the data into Ram, it can be written as many times as you like, but then the data will be lost if the power is removed from the stamp.
Hope this helps,
Chris
csavage@parallax.com
You may also want to look at this page:
http://www.parallax.com/html_pages/resources/custapps/app_nearspace.asp
Paul's group does near space launches-
Ryan
Ryan Clarke
RClarke@Parallax.com
P.S. That part number is apparently more like 24LC32.
Could anyone help me to write down and retrive the measurments that I whould get during our launch with the attached program?
Ive been at it for awhile now trying differnt things, but with no luck. I am trying to use the WRITE and READ commands, but nothing shows up in the debug window.
' ========================================================================= ' ' File...... MEMSIC2125-Dual.BS2 ' Purpose... Memsic 2125 Accelerometer Dual-Axis Demo ' Author.... (C) 2003-2004 Parallax, Inc -- All Rights Reserved ' E-mail.... support@parallax.com ' Started... ' Updated... 07 SEP 2004 ' ' {$STAMP BS2} ' {$PBASIC 2.5} ' ' ========================================================================= ' -----[noparse][[/noparse] Program Description ]--------------------------------------------- ' ' Read the pulse outputs from a Memsic 2125 accelerometer and converts to ' G-force and tilt angle. ' ' g = ((t1 / 10 ms) - 0.5) / 12.5% ' ' Tilt = ARCSIN(g) ' ' Refer to Memsic documentation (AN-00MX-007.PDF) for details on g-to-tilt ' conversion and considerations. ' ' www.memsic.com ' -----[noparse][[/noparse] Revision History ]------------------------------------------------ ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- Xin PIN 6 ' X input from Memsic 2125 Yin PIN 7 ' Y input from Memsic 2125 ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- ' Set scale factor for PULSIN #SELECT $STAMP #CASE BS2, BS2E Scale CON $200 ' 2.0 us per unit #CASE BS2SX Scale CON $0CC ' 0.8 us per unit #CASE BS2P Scale CON $0C0 ' 0.75 us per unit #CASE BS2PE Scale CON $1E1 ' 1.88 us per unit #ENDSELECT HiPulse CON 1 ' measure high-going pulse LoPulse CON 0 DegSym CON 176 ' degrees symbol ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- xRaw VAR Word ' pulse from Memsic 2125 xmG VAR Word ' g force (1000ths) xTilt VAR Word ' tilt angle yRaw VAR Word ymG VAR Word yTilt VAR Word disp VAR Byte ' displacement (0.0 - 0.99) angle VAR Byte ' tilt angle ' -----[noparse][[/noparse] EEPROM Data ]----------------------------------------------------- ' -----[noparse][[/noparse] Initialization ]-------------------------------------------------- Setup: PAUSE 250 ' let DEBUG window open DEBUG "Memsic 2125 Accelerometer", CR, "-------------------------" ' -----[noparse][[/noparse] Program Code ]---------------------------------------------------- Main: DO GOSUB Read_Tilt ' reads G-force and Tilt ' display results DEBUG CRSRXY, 0, 3 DEBUG "X Input... ", DEC (xRaw / 1000), ".", DEC3 xRaw, " ms", CLREOL, CR, "G Force... ", (xmG.BIT15 * 13 + " "), DEC (ABS xmG / 1000), ".", DEC3 (ABS xmG), " g", CLREOL, CR, "X Tilt.... ", (xTilt.BIT15 * 13 + " "), DEC ABS xTilt, DegSym, CLREOL DEBUG CRSRXY, 0, 7 DEBUG "Y Input... ", DEC (yRaw / 1000), ".", DEC3 yRaw, " ms", CLREOL, CR, "G Force... ", (ymG.BIT15 * 13 + " "), DEC (ABS ymG / 1000), ".", DEC3 (ABS ymG), " g", CLREOL, CR, "Y Tilt.... ", (yTilt.BIT15 * 13 + " "), DEC ABS yTilt, DegSym, CLREOL PAUSE 200 ' update about 5x/second LOOP END ' -----[noparse][[/noparse] Subroutines ]----------------------------------------------------- Read_G_Force: PULSIN Xin, HiPulse, xRaw ' read pulse output xRaw = xRaw */ Scale ' convert to uSecs xmG = ((xRaw / 10) - 500) * 8 ' calc 1/1000 g PULSIN Yin, HiPulse, yRaw yRaw = yRaw */ Scale ymG = ((yRaw / 10) - 500) * 8 RETURN Read_Tilt: GOSUB Read_G_Force disp = ABS xmG / 10 MAX 99 ' x displacement GOSUB Arcsine xTilt = angle * (-2 * xmG.BIT15 + 1) ' fix sign disp = ABS ymG / 10 MAX 99 ' y displacement GOSUB Arcsine yTilt = angle * (-2 * ymG.BIT15 + 1) ' fix sign RETURN ' Trig routines courtesy Tracy Allen, PhD. (www.emesystems.com) Arccosine: disp = disp */ 983 / 3 ' normalize input to 127 angle = 63 - (disp / 2) ' approximate angle DO ' find angle IF (COS angle <= disp) THEN EXIT angle = angle + 1 LOOP angle = angle */ 360 ' convert brads to degrees RETURN Arcsine: GOSUB Arccosine angle = 90 - angle RETURNPost Edited (cannibalmonk) : 4/18/2006 12:27:12 AM GMT
