Sonic Boe-Bot
Well, here's my first project: Ultrasonic roaming
I bought a VEX ultrasonic sensor a few weeks ago and finally put it on my Boe-bot. The program makes the Boe-Bot drive in a zigzag pattern. If it detects something on the sensor (the range is set to about 2 inches) It turns a little bit. I would've posted a picture, but the attachment manager only lets me put in the code...
Are you asking a question, or posing a problem for solution, or just announcing that you've finished your project?
If either of the former, it's not real clear what the question or problem is. If it's the latter, you may want to ask to have this post moved to the Projects Forum, which is where completed projects are generally displayed.
Bruce Bates
<!--StartFragment -->
I just bought a VEX Sonar sensor and was wondering if you have a schematic of how you hooked it up?
Jim
