WAM - Digital Display?
1) Why 1 Kohm for each LED is used in chapter 6? Why not 470 ohm for each LED as in earlier chapter?
2) Are there any sample code·for·boe-bot navigation and the use of·gripper add-on?
mj
mj
·· The reasons are that you cannot draw more than 50 mA per group of 8 I/O pins.· With 470 ohm resistors when all segments were lit it would be too much current.· 1K resistors limit the current even further preventing this from happening with so many LEDs being lit at once.
csavage@parallax.com
