using a transistor to ignite an e-match (1amp)
Hello, I've done some searching on this forum, but it appears no one has used a transistor to ignite an e-match (electrical match). Here's how I think they work (please let me know if I'm wrong).
A transistor has 3 connection points: base, collector, emitter
In order for me to ignite an ematch I need to do this:
-connect the 'base' to an I/O pin on the Stamp
-connect the 'collector' to a seperate battery (the positive end)
-connect the 'emitter' to one side of the e-match lead
-connect the second e-match lead to the negative side of the battery
Putting the I/O pin closes the circuit, and connects the 'collector' and 'emitter' internally.
Do I need resistors somewhere in there?
How do I know if a transistor can handle the 1 amp of current?
Jon Williams
Jon Williams
Base goes to ground
Collector goes to a pin (with a resistor inbetween)
Emitter goes to one end of the e-match
Negative terminal of battery goes to circuit's base
Positive terminal goes to the other end of the e-match
Is that wrong? Everytime the pin goes HIGH (which should close the circuit), the voltage drop down to around 0.15 volts, even with a fresh new battery (or two batteries in parallel, or two batteries in series).
Please help
Thank you
Matt
*** Post Edit ***
Looking at your first Post, you have it described (basically, but not wholly so)·the way that it should be, but in that preceding this you have it all jumbled.· What gives?
One more thing -- the tab/heat-sink is the Collector, same as the middle pin [noparse][[/noparse]so, watch it!]
Post Edited (PJ Allen) : 5/7/2006 6:32:02 PM GMT
Matt
PS: I wonder why I didn't do what I said in the first post...
