BS1 vs. BS2, will this work with a BS1? — Parallax Forums
evergreenevergreen Posts: 43
edited 2006-04-15 20:11 in BASIC Stamp
Hello, I'm working on a rocket related project, and was hoping I could use a BS1 due to its smaller size (but I'm slighly more familiar with the BS2).
The BS1 will only need to do a few SIMPLE functions:
1) read values from a 12-bit ADC (LTC1298)
2) open and close a transistor
3) operate 1 or 2 LEDs
4) store a few data values from the 12-bit ADC (at least one data value, but the more the merrier).
Will the BS1 be able to handle these tasks?
    edited 2006-04-15 05:31
    Evergreen,
    Yes, the BS1-IC can do this task.
    1) Example code is here - http://www.parallax.com/dl/docs/prod/appkit/ltc1298.pdf - three I/O pins required.
    2) HIGH and LOW - one I/O pin
    3) HIGH and LOW - one or two I/O pins
    4) READ and WRITE - limited memory 256 bytes, but easy access to the EEPROM - no I/O pins
    Depending on how much data you want to store (4) everything seems quite appropriate for a BS1-IC.
    By the way, be sure to see our Near Space articles since you are interested in rocketry. You can find them at the bottom of this page: http://www.parallax.com/html_pages/resources/custapps/app_nearspace.asp.
    Sincerely,
    edited 2006-04-15 06:54
    Which BASIC Stamp are you going to use?· You have another thread asking about doing the same thing for the BS2.
    csavage@parallax.com
  • evergreenevergreen Posts: 43
    edited 2006-04-15 16:18
    I'm not sure yet. I might just end up with the BS1 because of its small size.
    edited 2006-04-15 16:21
    I have another question (should I put this as a new thread?). What's the difference between a BS1 and a BASIC Stamp Rev. Dx? They appear to have the same specs.
    Matt
    edited 2006-04-15 16:42
    Matt,
    Just the package format. One is a SIP and another is a small PCB with prototype area. Your choice!
    Ken
    edited 2006-04-15 18:52
    Okay, sounds good!
    Are any of the holes in the Rev. Dx board connected? Or are they all independent of each other (if so, does that mean I have to strictly use wire wrap?)?
    http://www.parallax.com/images/prod_jpg/27100.jpg
    edited 2006-04-15 19:12
    If you look carefully you can see that the first column of holes is connected (matches the labels to the left of the header).
    Jon Williams
  • Buck RogersBuck Rogers Posts: 2,211
    edited 2006-04-15 20:03
    Hello!
    Overworked and underpaid consultant's opinion here:
    That PCB that the Stamp Dx wears, isn't it roughly the same form factor as the one for the BS1's carrier board? (The simple one not the complex one.)
    Buck Rogers
    www.gregg.levine.name
    They are about the same size, but you can see that the carrier has more prototyping holes (since the BS1 parts are on the BS1-IC).
    Jon Williams
