CEMF clamp diodes
Hi!
Motor control trouble again....So, I have a 10A relay-and-mosfet controller. I am worried about the CEMF. What I have now is something very weird, advised by a guy at Gateway Electronics, who probably misunderstood me. He gave me a 1N4003 or something to that effect and told me to put it in line with my load...which makes no sense, because I'm running PWM through it as well. I also have some coils in line to absorb stuff, but I'm still worried. Also, I consequently have the~1V voltage drop in there. Luckily (I believe) I have not stuffed 10A through it yet, still testing...
Any advice?
Rafael Send
Any advice?
Rafael Send
· Do you have a scanner?· Maybe you could U/L a schematic of your circuit?
N.B. --
· Typically, you want to have your "CEMF" diodes across/in parallel with·your relay coils (reverse-biased).· If you're doing a H-bridge, then you (also) want to have "CEMF" diodes across your semiconductors (in parallel with C-E, S-D -- again, reverse-biased.)
Post Edited (PJ Allen) : 4/15/2006 2:44:36 PM GMT
So, I don't have a scanner, so I will try drawing it in software.
I have the diode across my relay coil, I was wondering about the motor emf...so for that I put a diode across the mosfet?
Rafael
However, the whole setup works at low current...I haven't tried to stuff 10A through yet, luckily...
Rafael
*&#@^$&*Attachements(@#&@*()%
Post Edited (flyingfishfinger) : 4/15/2006 9:59:35 PM GMT
A 9v relay coil may energize with as little as 5V (not so surprising.)· I think you should turn the relay on by sinking through the transistor [noparse][[/noparse]also shown.]
I wouldn't use the coils in series with the motor (a-la "Gateway".)
Schematic attached.
-- PJA --
Also, what sort of diode should I use on the mosfet? Yes, it is PWM and remember it's a 10A motor at 12V on there...
You said "also shown" - do you mean your schematic or mine?
Rafael
Post Edited (flyingfishfinger) : 4/15/2006 10:29:46 PM GMT
· Here's much the same but with an added CEMF diode -- it's more important than the other across the FET (it's seen next to the top contacts.)
· I would use 1N4007.
Y'know the current of the motor has nothing to do with the diode ratings.· As the diodes are backward-biased, the motor current does not pass through them.· They are serving as a current path for short-lived kick-back spikes (which aren't a function of or proportional to·motor current.)
My Robot DNA book puts a diode from the mosfet-relay connection to V+...???
Post Edited (flyingfishfinger) : 4/15/2006 10:45:05 PM GMT
Not good enough I guess
· What's the worst that could happen?· The $2 FET might go POOF!· End of The World?
Thanks and forgive my inexperience in this matter...it's my first current controller [noparse]:)[/noparse]
Rafael
It's the same as my second (previous), only shown more clearly.
Post Edited (PJ Allen) : 5/28/2006 5:57:55 PM GMT
Thanks a bunch
Rafael
