Voltage Regulator
I'm pretty new to electronics, so please bear with me.
I'm looking for a voltage regulator like the LM7805 that can handle more current. I have a device that draws 2 amps, so I will probably need something above that.
Here is what you are looking for LM323AK 5VDC 3Amp Voltage Regulator
And here is a link where you buy one at
One thing this is a T-O3 case not a T-220 case you can find them in a T-220 case but
unless you have a GOOD HEAT SINK you will have HEAT problem with them
a large heat sink for a T-220 is hard to find T-O3 are eaiser to find
www.goldmine-elec-products.com/products.asp?dept=1170
I hope this help you
Sam
You might start here for information on higher curent supplies then dig around here for some schematic designs.
Vern
Thanks for those links
I want to built one of those higher curent supplies
Sam
