Visual Basic and BS2sx — Parallax Forums
chazbrazilchazbrazil Posts: 27
edited 2006-04-13 15:38 in BASIC Stamp
I am attempting to communicate via the Comm port to the BS2sx through Visual Basic so I can log data. What is the serial setting? (Baud rate, parity, etc.?)
    edited 2006-04-13 14:38
    You can set the baud rate the BS2sx uses through the 'baudmode' parameter. I find 9600 baud most useful, but you'll have to look up in the manual what baud-mode constant for the BS2sx corresponds to 9600 baud.
    The BS2 only does 8-bit, no parity or 7-bit, even parity. Again, selected with a flag on the baudmode constant.
    And if you use the 'programming' port, (SEROUT 16, ...) then I believe you should use 'Inverted' mode -- again, yet another flag on the Baudmode constant.
  • chazbrazilchazbrazil Posts: 27
    edited 2006-04-13 14:42
    allanlane5 said...
    Do you by any chance have any sample code that shows a visual basic and bs2 communicating?
    edited 2006-04-13 14:44
    Funny you should ask...
    Please see the attached.· Note it is for a BS2, so you'll need to change the
    baud-mode constant for a BS2sx.· I keep saying this, because it can be
    really un-obvious to the first-time BS2 user, who typically puts a value
    like "9600" in there, expecting that to work.
    edited 2006-04-13 14:49
    csfan worked out a set of programs, recently -- http://forums.parallax.com/showthread.php?p=580535
    (it's one-way comm, the STAMP/boebot is receive-only)
    edited 2006-04-13 15:20
    How do you reference the Sout Pin? You use S_out in your program and it wont recognize
    edited 2006-04-13 15:35
    Well you can define "S_out" as:
    S_out CON 16
    and that should work. Or, you could have used the 'A' example, and it should work unmodified.
    But good catch, that.
    allanlane5 said...
    S_out CON 16
    Oh sorry... I'm still trying to get a hang of all this.
