hitec hs-755hb servo
hello, i'm trying to control a hitec hs-755hb servo with my bs2 stamp. whatever pulsout commands I send it slowly rotates all the way around and then stops. I've tested the circuit with a standard servo from parallax (it works fine), I've also tried changing the pulsout values. I've also noticed the 7805 I'm powering it with is getting very hot, although the servo is only supposed to draw 250 ma
I'm using the following as test code, with changes to the pulsout command to see if different pulses have an affect.
servopin con 8
x var byte
main:
for x = 1 to 20
pulsout servopin, 300
pause 20
next
for x= 1 to 20
pulsout servopin, 1500
pause 20
next
goto main
here are the specs I have on the servo
ontrol System: +Pulse Width Control 1500usec Neutral
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.28sec/60 degrees at no load
Operating Speed (6.0V): 0.23sec/60 degrees at no load
Stall Torque (4.8V): 153 oz/in. (11kg.cm)
Stall Torque (6.0V): 183 oz/in. (13.2kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 400usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 8mA/idle and 230mA no load operating
Current Drain (6.0V): 8.7mA/idle and 285mA no load operating
Dead Band Width: 8usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Indirect Drive
Bearing Type: 1 Bearing and 1 Oilite Bushing
Gear Type: Karbonite Gears
Connector Wire Length: 11.81" (300mm)
Dimensions: 2.3" x 1.1"x 2.0" (59 x 29 x 50mm)
Weight: 3.88 oz.. (110g)
servopin con 8
x var byte
main:
for x = 1 to 20
pause 20
next
for x= 1 to 20
pause 20
next
goto main
360 Modifiable: Yes
csavage@parallax.com
I put a pause in between and it did not help - the servo moves clockwise regardless of what pulse is sent to it.
