Specialized counters
Where is explained the use of these 'two specialized counters' that I keep hearing about ?
I was puzzled reading some of the code·writen around·those counters.
I have not searched the field, but I'm not sure if much pulblic information exists about those or the video peripheral. I believe Parallax is writing that stuff up during this period prior to formal release.
Cheers,
Peter (pjv)
Jon Williams
Don't visit my new website...
Wow! I think I need time to assimilate this information. Anyway, now·I understand why these are called 'specialized counters' although 'counters' is a little humble name for such powerful registers.
I see this subject has a lot of possibilities.·I can even foresee·a book: 'Recipes for·exploiting·Propeller's specialized counters".
Well at least I expect an article on N&V dedicated to this subject ! ;-)
Jon Williams
Jon Williams
I was able to get the correct clock frequencies out of the code posted above, but,·there was a very small error·so the two clock pulses were not in perfect sync.
In my application Pin 1·needs to be exactly·1/64 of Pin 0. ·I can work out timing to sync the two clocks.
Maybe I'm completely·unable to grasp the concept. Maybe·someone could help shed some light on these wonderful counters·since little documentation is currently available for them, that I can find.
Here is the code I’ve been using to test the counters.· Currently it is set to output 40MHz on pins 0 and·1.
-Dan
Post Edited (Direct Digital Labs) : 7/31/2006 3:09:12 PM GMT
