Connecting Two Stamps
Greetings to all!
I've got a quick question about connecting two Stamps together.
One is a BS2SX, the other is a Javelin.
I plan on using SERIN and SEROUT to communicate between the units.
My question is this. The pins I'm using are part of a PCB that primarily wasn't intended to be used for communication between stamps.
Each of the 5 pins I need to use have a LED and a 1kOhm resistor hanging off to ground (should pull about 5mA).
So, what are the source current limits for the Stamp units when using RS232 TTL (SERIN/SEROUT)?
Is it the same as if you were driving the pins High/Low manually (30mA/Pin, 60mA Total for the entire unit)? Or is it something else?
Cheers!
Cheers!
·· First of all RS-232 and TTL are totally different signal levels.· You will be dealing with TTL, not RS-232, and experience has shown me that the LEDs don't usually cause much of a problem, although the baud mode you choose (inverted or true) will determine if the LEDs are on all the time but pulse off during activity or if they're off except pulsing during activity.· Think of them as little activity indicators.· I only say this because it's already there.· I don't normally recommend wiring things like this.
csavage@parallax.com
The baud mode will most likely be 9600, non-inverted.
Just curious- why don't you recommend wiring them like this? Is there a particular reason (Aside from the obvious fact of needing the LED's), or could there be some sort of long-term effect on the controllers?
If need be, I can replace the LED's with wire, just leaving the resistors. I can also replace the 1KOhm units with 10KOhm or larger. I just figured that since they come with the kit, might as well use 'em.
Thanks!
