Weatherproofing
meredth78
Does anybody know of a product to encapsulate my·circuit board in to completly weatherproof if?
Do you ever want to be able to work on it again?
Steve
Happy new year
Tim
The epoxy I like is DP270 from 3M, electronic encapsulation epoxy. It has a long pot life and very low viscosity to flow into voids, good thermal and mechanical properties, and does not chemically attack components.
Tracy Allen
www.emesystems.com
Able to survive being rained on?
Able to survive being submerged?
Able to survive being bashed through brush and ice while attached to a Labrador Retriever's collar?
Best Regards
Manuel C. Reinhard
Have you ever thought of using canning wax??? I have used it on small flasher boards, and had no problem with water getting in....
Bob N9LVU
3M's epoxy is by far the easiest to get ahold of.
The main question is whether or not you have a great deal of heat envolved.
If you encapsulate, you really limite the cooling properties of all the components unless you attach heat sinks [noparse][[/noparse]where appropriate] that extend out of the encapsulation.
If their is very little heat, silicon rubber from a hardware shop will do it and be easier to cut into if you need to repair.
On the backs of circuit boards that I have on my bench, I use hot glue to protect from accidental shorts.
It can be peeled off for repair.
·· "something like the hard black plastic resin that is poured into a small open top enclosure with just the hook up wires sticking out"
Tim
Tim
