Simple Test Code — Parallax Forums
Simple Test Code
Thomas LThomas L Posts: 3
edited 2006-04-18 11:23 in General Discussion
Hi, I wonder if anyone could provide me with a simple code to test if the Parallax camera is working with the javalin development kit I have.
Also, I just got the PDB and it has a USB. Two questions: Can it be used to connect the board to the PC? Second question: Is there any support for the use of this USB in your own code (like reading a GPS module)?
Best // Thomas
Post Edited By Moderator (Chris Savage (Parallax)) : 4/7/2006 2:15:50 PM GMT
    edited 2006-04-07 14:16
    Thomas,
    ·· I provided you will a subject (instead of "no subject") but I am stumped at your line about the Parallax Camera.· We do not have such a device, unless you are actually referring to something else.· As for the USB Port, when the driver is installed on the PC, the PC looks at it as a Serial/COM Port.· Even though it's USB it's being treated as a Virtual COM Port, so everything is still serial.
    csavage@parallax.com
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2006-04-07 15:14
    Do you mean the CMUCAM ??
    http://forums.parallax.com/showthread.php?p=468574
    regards peter
  • Thomas LThomas L Posts: 3
    edited 2006-04-16 15:50
    The little camera on two plastic rods and a PCB with a 10-pin connector that is used for the Basic Stamp to chase a red ball is soldby your rep here (ELFA) as working with the Parallax board. That is why I wondered if there was a code for that device.
    Ciao // Thomas
    PS A camera and code for the PDB would also be fine!
    //ds
    edited 2006-04-16 17:29
    Can you provide a link to that camera module,
    as ELFA does not mean anything to me.
    regards peter
    edited 2006-04-18 11:03
    Kameramodul
    CMUcam robot version
    Fabr Parallax
    En version av CMUcam som
    edited 2006-04-18 11:12
    Java classes for the Parallax CMUcam are in this thread
    regards peter
    Here is your swedish text translated to english:
    CMUcam robots version Fabr Parallax A version of CMUcam as is more suit for that direct fabricate on Boe - Remedy. That version lacks certain functions am comparing with this ordinary CMUcam. This for that the is intended that fabricate on a Boe - Remedy and accordingly always is was connecting to a Basilica Stamp - module. TRANSFER ex be wanting sp
