LCD help
Hello I just bought a bastic stamp a few weeks ago and I·can't stop·playing with it ever since.... anyway
I just got this emerging displays technologies LCD screen with the same hitachi driver as the parallax one on the back and the pins and everything are also setup the exact same way.. I'v tried about 3 different example programs to try and get this this to say something but I·CANNOT get this thing to work, I wired it·about 5 differnt times, i used the program and scematic in the Stamps In Class thing and it still dosen't work, is there anyway I can get like 1 character or dot to light to see if this thing works???
Can you post a link to the technical information to the LCD you have?
Jon Williams
heres the link to the pdf file
http://www.allelectronics.com/spec/LCD-97.pdf
Jon Williams
Jon Williams
csavage@parallax.com
It said recommended resistor R: VDD- VO greater then or = to 1.5V
I get it now so, I could just ground it and it will be on all the time correct???
Jon Williams
Post Edited (Chris Savage (Parallax)) : 4/7/2006 7:27:37 PM GMT
thanks
OS-X: because making Unix user-friendly was easier than debugging Windows
