Compass — Parallax Forums
Compass
AmitAmit Posts: 27
edited 2006-04-07 13:23 in General Discussion
I was looking at the Parallax implementation of the Hatichi compass and had some questions.· I couldn't find any information regarding the board outline dimensions or pin locations.· I would like to put this on a PCB and didn't want to mess that up.· Also does the compass work upside down?· Any help with this product would be appreciated.
Thanks!
Amit
    edited 2006-04-06 23:48
    L = .5", W = .44", H = .45" (Including pins).· As for working upside down...In theory I guess I could, but it would read everything in reverse like a mirror image on one axis·if it did.
    csavage@parallax.com
  • AmitAmit Posts: 27
    edited 2006-04-07 03:31
    Chris,
    Thanks for the info!· But for the PCB i would need a diagram of the pin locations or something of the sort so that I could place the thru-holes in the right location.· Anyone have any information on this?
    Thanks!
    Amit
    edited 2006-04-07 04:06
    Amit-
    It works upside down as well as right side up.
    Ken
    edited 2006-04-07 04:52
    Amit,
    ·· Everything you could want to know about this Compass Module is right in the documentation on our website including measurements, pinouts, electrical specs, samples code, etc.
    http://www.parallax.com/dl/docs/prod/compshop/HM55BModDocs.pdf
    Thanks a lot!· I didn't even see that.· I had just skimmed through·it looking for a mechanical drawing.·
