COG and Force Run
is it possible to identify a COG and have it take the time slice to process. I guess my question is broader is it possible to control which COG will need to process its code from another COG.
Suppose I have 3 COGs in my app.
1) runs general sensors and sets feelers out to the env
2) processes the data sensed by #1
3) processes logging and Output
Can #1 selectively ask #2 or #3 to process its stuff...
thanks, ALIBE
thanks, ALIBE
Jon Williams
what if I want to ::cognew() and then call it only on demand.
if ( x==y){
// cog 1 ::doThis();
is it only possible by unloading the cog and then ::cognew() again. If so, what is the performance hit on the ::cognew() call - does it depend on what's running in each cog (I guess).
thanks
sorry forgot to add, in you note I did not see if it;s possbile to ID a specific cog and have it take the run.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 4/7/2006 6:03:37 AM GMT
Thanks.
What sort of cog management is avvailable? Do we have a way to see which cogs are idle? which are running assembler versus interpreted code? I take it that the spin-running cog is usually the first to stat and is probably in cog0 (?) but can you envision a device monitoring cog that is monitoring the others in some way? I'd write something like this first off -- if I had a chip and spin/asm reference manuals, of course.
Other than that, it sounds like you are trying to apply a "larger machine" paradigm to an environment in which it's not a good fit...
...or I could just as easily be missing the point...I've been doing a lot of that lately [noparse]:)[/noparse]
6+6=10 (Long live the duodecimal system)
Yes, you are precisely correct. I am thinking of emulating a CDC6600. The architecture of that machine was surprisingly similar to this chip, in fact the memory of the cogs is quite close to that of CDC 6000 series PPUs and the "slot int he barrel" technique is identical. The 6600 software architecture included a central processor as well but you could easily do a lot of work using just the PPUs and the operating systems were entirely designed around these computers, each based on the design of the CDC-160A
Understanding what was happening in the larger system was often quite a problem simply because so many things can be going on at once. Making sense was often a amtter of having code that would run in a PPU and "tell" you want was happening elsewhere.
For starters I need a bit of code that will dump the contents of the registers and memory in a cog to a specific location in the main memory.
MMmm and then I need something to peek and poke into memory in the cog, change registers, etc. Hmmm.
Anyone likely to make an ICE for this chip?
The registers and memory of a COG can only be accessed from within that COG.
(At least I can't see any way to do that. And frankly, the possibility of directly reading/writing another COGs memory is too terrifying to behold. Too many things that can go wrong)
But if the CDC6600 is so close to the Propeller in design...
Why don't you try to emulate it with a couple of FPGAs?
I'd love to read a bit about how Chip built and tested the COGs using FPGAs.
(I'd pay to read it in fact. Not much, but still... )
Don't visit my new website...
What's the register structure for the cog?
Anyone have the instruction that I can look at?
Again, is there an ICE in the future? Or maybe a cog simulator?
I think you may find that trying to turn the propeller into a classic multiprocessor will introduce a lot of overhead and not produce much benefit. The propeller isnt a multiprocessor in the traditional sense, its a multicontroller. Certainly there would be applications where a cog monitor would come in handy, but I wouldn't implement it as a baseline.
Cog memory is 512 longs (2Kbytes) with the last 16 being special purpose registers.
Just tossing my two bits worth into the bit bucket
KK
Multicontroller - splendid invention!
Since this is something that's going to get asked again and again and again, I rather hope Parallax adopt that word...
Seve
Multi-Microcontroller is an understatement of Multi-Microprocessor. I heard in some other threads that Parallax is calling this a "MultiProcessor".
I personally don't really worry abt it - just as long as it is doing what I needed [noparse]:)[/noparse]
However, from an architectural standpoint, I would think of propeller as a multiprocessor and not multicontroller. It is first a multiprocessor and does help drive the multicontroller behavior.
Is it not. Please correct if I'm wrong. I don;t want to be in denial
