Workable WiFi solution for a robot
I am looking for·a WiFi solution in SDIO or custom format. There are plenty of solutions for Embedded OSs but I need one that I can control myself.. Anyone knows about any solution that can be controlled without a proprietary driver ?·Until now I have been using a·PCMCIA card from Prymax that is well documented·but it takes too much power. I need something·not too power hungry.
BTW, I do need the bandwidth of WiFi. Bluetooth solutions are not fast enough for my application.
Just a thought.
- K
Failure is not the only punishment for laziness; there is also the success of others.
- Jules Renard
Doh!
- K
- Jules Renard
http://www.maxstream.net/·and·· http://www.ember.com/downloads/pdfs/article-iee-11-04.pdf· might give you an idea or two. Multiple units are no problem, and unless you need exceptional range, might fit the bill.
Jim
In the end, it seems that it's all about getting the LEDs to blink....
I wanted to add WIFI remoted capabilities to my BOE BOT but at the time (4 years ago) it was something I couldnt afford.
Fortunately, somebody offered me a WIFI enable IPAQ (h4155).
So I bought the iPAQ's serial cable, programed a robot controlling software for the PC th robot will be talking with, programed a TCP/UDP to SERIAL proxy software (in C#, but can be written using other langage) and installed it on my IPAQ under WINDOWS MOBILE 2003, programed a BASIC STAMP 2e software to act as a sensors and actuators controller.
The IPAQ's serial cable was directly set to the BOE BOT motherboard, while the PDA was lying under, tied on the Bot's aluminium frame with rubber bands,....Et voil
