question about turning multiple leds on
hi
I just want to know quickly how many leds can I turn on and off ( how many outputs can I use ) with a resistor of 360 ohms for each output
quickly please
thank you
quickly please
thank you
You'll get better, quicker answers when you provide more complete information with your questions.
Jon Williams
but if i want to use a digit display ( with number eight ) with the basic stamp 2, is it okay if i put a HIGH value with the ( VDD Voltage 5 volts ) to five outputs all in the same time and each output has a resistor of 360 ohms ?
Jon Williams
First things first: get out your meter and using the diode check function measure the forward voltage of one of your LED segments.
Jon Williams
