Parallel LCD with SX.
Hello All
I'm having trouble finding code/examples for using the SX with a parallel LCD.·Plenty of serial LCD out
there. Tryed Google and a search on the SX forum's search engine. Even tryed the SX List, and this seems
to be the only sample found
http://www.sxlist.com/techref/ubicom/lib/io/dev/lcd/4bitlcd_sx.htm
although I have my doubts this will work with the SX.
Has anyone hear had any luck with parallel LCDs.·
Any tips or ideas will help.
Thanks for reading
Gorodon
Thanks for reading
Gorodon
Jon Williams
examples are aimed toward the serial LCDs and not the parallel LCDs.· For the record, the reason
for a parallel LCD is I already have a few on hand that I'm "reusing" from previous·PIC projects.
Thanks again
Gordon
Some people think that LCD example program is FOR a serial LCD. It's actually to MAKE a serial LCD from a standard parallel LCD module.
It is one of Jon's best example programs. Check it out.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
Gordon
Find attached a code for a parallel LCD that uses the 4-bit mode.
I hope it helps.
Aime
Gordon
