BS2 and a rotary dip switch.
Hey folks, I basically want to integrate a rotary dip switch into my project, but how would I be able to detect the different states of the switch through the BS2? Basically I have a rotary dip with 1-10 positions and I would like each to represent the amount of minutes for a count down timer. Thanks.
Which DIP switch are you using? The answer lies in how it is supposed to be wired up, and if it produces some kind of specialized output (BCD, HEX, gray code, etc).
Bruce Bates
<!--StartFragment -->
Once you read the pin state, you just need to interpret the value in code (like Bruce said).
OS-X: because making Unix user-friendly was easier than debugging Windows
Thanks!
The programming part is easy, though. With the "1" terminal connected to P0, the "2" terminal connected to P1, the "4" terminal connected to P2, and the "8" terminal connected to P3, the value of the switch is INA (or ~INA if it's active low).
I don't know where the link went to, that was in your message above, but if you go there, and download the data sheet, that will show you almost everything you need to know. Personally, I'm not real keen on how they structured the truth tables, so I have re-structured them here for you, in a manner that is hopefully more understandable. My tables and theirs SHOULD be identical, except for the actual format. If not, I may have a typo·in mine:
/code
Connection Pin··· Pos'n
· on Switch······ Number
· 8· 4· 2· 1··········· N
··1··0· 0 ·1· ······· · 9
··1··0· 0· 0 ········ · 8
··0··1··1··1········· · 7
··0· 1· 1· 0········· · 6
· 0· 1· 0· 1········· · 5
· 0··1· 0· 0········· · 4
· 0· 0· 1· 1········· ··3
· 0· 0· 1· 0·········· ·2
· 0· 0· 0· 1········· · 1
0 = inactive, low or zero
1 = active, high or one
code/
BCD = binary coded decimal number representation
HEX = number representation using base 16 numbers (0=>F)
When using single digit BCD codes (as you are above) they are the same as the HEX representations of those same BCD numbers. Note the descending progression of bits above. As they are·read from left to right, the columns actually represent·the values of ·23 22 21 20 or 8, 4, 2, 1 as they are so labelled. Note also that the position number is nothing more than the SUM (left to right) of the ACTIVE columns! So, said differently, the qualitative VALUE is actually the POSITION number.
PBASIC permits us to read four, eight or all pin ports at once, if we choose to do so, rather than reading only one pin port at a time. The only caveats are: the pin ports must be in succession, and they must start on certain boundaries. Here are those permissible multiple pin ports and their respective names:
/code
· Pin Port Sets Permissible
| 0-3· | 4-7 |·8-11· |·12-15 |<= Pin port numbers
| INA |·INB·|· INC· |· IND·· |····· Four input ports at a time
|·· ···INL···· |······ ·INH······· |····· Eight·input ports at a time
|··· ····· ··· INS·· ··············· |·····All 16·input ports at once
So (say) our switch pins (8-4-2-1) are hooked up to pin ports 0-3 respectively, we can read them all at once by saying:
Dip_Switch VAR NIB
Dip_Switch = INA· 'Grab all four pin ports (0-3) at once
Now we can use a computed GOTO to perform the necessary actions based on the reported position (based on its value):
ON Dip_Switch GOTO POSN1, POSN2, POSN3, ... POSN9
POSN1:
· 'Do this
GOTO DIP_Exit
POSN2:
· 'Do that
GOTO Dip_Exit
POSN9:
· 'Do something else
Dip_Exit:
code/
That should get you well on your way.
Bruce Bates
