SIC requirements
When a(n) SIC description says it requires the Board of Education, will a Professional Development Board also work?
OS-X: because making Unix user-friendly was easier than debugging Windows
·· You could use the Professional Development Board if you're not too reliant on the wiring diagrams, since they won't be accurate.· Basically the PDB has all the same things a BOE has (except an AppMod socket) and more, including many things that you would normally wire up on the BOE breadboard.
csavage@parallax.com
·· You can always peruse the PDF version of any SIC Manual from our website before buying anything.· This way you can see what is involved in that particular curriculum.· Take care.
