stepper motor control with uln2803
I purchased the stepper motor from parallax, it is 7.5 degree/step 12v 100ohm
using the instructions on this link
http://www.parallax.com/dl/docs/prod/motors/Stepper_Motor_27964.pdf
I have tried the full step(high torque) way and the high precision way of driving the motor. But both ways it barely takes any effort at all to stop the motor from spinning with my hand. What can I do to increase the torque even more?
I am driving the chip and motor with 12v and·5 volts for the logic, just like in the diagram in the pdf link above.
·· The Stepper Motor we carry isn't very high-torque and is intended for learning.· If you need more torque you should purchase one with the specifications you require at the voltage you're using.· It also helps to make sure your power supply can provide enough current.
csavage@parallax.com
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Here is the basic stamp code i made to run it, it's nothing special, just threw it together to see if i could get the motor to turn
' {$STAMP BS2}
' {$PBASIC 2.5}
'P0 is enable a
'p1 is enable b
'p2 and p3 is coil 1
'p4 and p5 is coil 2
enableA CON 0
enableB CON 1
high enableA
high enableB
x VAR Word
DO
FOR x = 0 TO 10
· GOSUB revs
NEXT
FOR x = 0 TO 10
· GOSUB foward
NEXT
LOOP
foward:
'step1:
· HIGH 2
· LOW 3
· LOW 4
· HIGH 5
· PAUSE 20
'step2:
· HIGH 2
· LOW 3
· HIGH 4
· LOW 5
· PAUSE 20
'step3:
· LOW 2
· HIGH 3
· HIGH 4
· LOW 5
· PAUSE 20
'step4:
· LOW 2
· HIGH 3
· LOW 4
· HIGH 5
· PAUSE 20
RETURN
revs:
'step4:
· LOW 2
· HIGH 3
· LOW 4
· HIGH 5
· PAUSE 20
'step3:
· LOW 2
· HIGH 3
· HIGH 4
· LOW 5
· PAUSE 20
'step2:
· HIGH 2
· LOW 3
· HIGH 4
· LOW 5
· PAUSE 20
'step1:
· HIGH 2
· LOW 3
· LOW 4
· HIGH 5
· PAUSE 20
RETURN
Post Edited (Vertex78) : 4/1/2006 3:27:37 AM GMT
Dave
Dave Andreae
Tech Support
