LCD 4x20 HD44780
I got a 4x20 LCD with the attached specs, and connected and·tried it with BS2
but it doesn't work. Anyone knows if this LCD is compatible with BS2.
Lee
Lee
Jon Williams
All connection are good, now I get a very blur display, which can only be read from a certain angle.
Even though I already grounded the contrast pin (pin #3). Wonder should I need a negative
voltage for this LCD? Attached on my previous message is the specs docs.
If yes, how can I generate one ?
Thanks in advance
Jon Williams
0 get the best, but still unreadable. Unlike my other 2x16 LCD.
Wonder if there is other type of LCD than regular that may need negative voltage
at Contrast pin ?
Yes, indeed the contrast pin need negative voltage of
-5.7 Vdc with relative to 0/GND.
Now they are dark and clear.
LCD made by OPTREX model # DMC20481.
