DCE RS-232 appMOD ??
· I am having trouble with a BS2p40 and the data sent using SEROUT.· I am utilizing a few programs to check the serout information.· Here is what I am doing.· I have a basic stamp that all I want to do is send a byte of information to a Visual Basic.net program.· I used the software that is downloadable with the dce appMod kit with a javelin stamp and everything is fine. I send a 2 and the VB program recognizes a 2.
Now with the BS2p40 I send a 2. and the VB program recieves like 249, forgot the exact number it is not in front of me.· I am not sure why, but I think it has to due with the BS2p and what is exactly being sent, is it the ascii value of 2 or is it in hex.· The code that comes with· the Java stamp, (i am a java guy but need to use BS2p) has set up UART class that handle everything all I do is specify what I am sending.· The code that comes with the appmod is similar but the data is getting converted or sent differently.
ANY HELP??
ANY HELP??
The best part is, you'll probably never have the same problem again!
There's nothing like working through a problem to a successful conclusion.
Cheers
