Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
reseting stamp kit — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
reseting stamp kit
chihi
6
2006-03-30 23:28
edited 2006-03-30 23:37
in
BASIC Stamp
is there a way two wire a reset switch seprate from the on on the basic stamp board? if so how
Jon Williams
6,491
2006-03-30 23:30
edited 2006-03-30 23:30
Yes: connect a normally-open push-button between the RST pin and Vss (Note that there is no socket for the RST pin).
Jon Williams
chihi
6
2006-03-30 23:32
edited 2006-03-30 23:32
thank you ill try that is that the pin connected to the chip labled rst?
Jon Williams
6,491
2006-03-30 23:35
edited 2006-03-30 23:35
Yes, it's pin #22 on the 24-pin module.
Jon Williams
chihi
6
2006-03-30 23:37
ok thanks
Sign In
Register
to comment.
Jon Williams
Jon Williams
