IR Buddy question.
Is it possible to transmit a logic signal from one to the other without a basic stamp? I want to transmit a logic level signal, no data. I am using a IR LED and IR phototransistor right now but the sun is interfering with it (false triggering). I also need it to be as fast as possible and not add or shorten the length of the original signal. Any help is appreciated.
HIBITDAC
HIBITDAC
More info is probably required to get more detailed.
If you look at the pdf information file on page·3 you'll see its not just an IR detector, but it detects pulses of IR occuring at a specific flashing rate, the second diagram on page 3 shows it is designed to detect IR pulsing at 38 kHz. Sunlight and internal lighting doesn't flash like this so it doesnt detect them. Since you dont want a stamp in the mix, you will have to use a 555 like Tom said, to flash your IR LED at 38kHz, and turn on the oscillation of the 555 when you want the motor running, and turn it off when you dont. You can do this by using an AND gate, where one input is from the output of the 555, and the other input is the trigger signal, and the output of the AND gate is connected to the IR LED and current limiting resistor.
Current Muppet Terror Level:
Thanks Again
HIBITDAC
6+6=10 (Long live the duodecimal system!)
HIBITDAC
