running at 50MHZ with 3V
Hello everybody!
I have make a project using SX28 running at 50MHz with 3V power supply. Before I started the project, I tested that·the SX28·can run·with·the Murata·50MHz ceramic resonator·at·3V supply (using a simple flashing LED programme). During the development, I test everything with SX-Key debugger. However, as I completed the code for my project and tested it along, I found that it can't run properly at 3V. The power supply has to be more than 3.8V·in order to make it·run properly.
I have already used a 0.1uF ceramic and 47uF eletrolytic cap for power bypass.
What is the problem? What can I do to maintain the configuration of 50MHz, 3V and using a ceramic resonator. Or is there any solution that enable me to maintain 50MHz at 3V?
Is your oscillator failing to run?
If so, it may be the oscillator settings, it may be the lack of a resistor in parallel with it [noparse][[/noparse]usually 1meg].
The shift to a lower voltage may under-power the resonator which lacks·fine tuning.
My personal goal is to operate at 3.3volts.
It seems that many ICs are tolerant to the range from 3.3 to 5.5 volts, so I can buy for either. Also, if you consider diodes usually have 0.7volts of voltage drop, I suspect that lower voltage ICs must stay about an absolute minimum of about 4 x 0.7volts = 2.8volts. You are getting quite close to that. Being higher gives you more leeway as you actually have more power to correctly drive the system.
Trying to bounce off the absolute minimum may force you to sort and select parts from a larger population as production runs do vary.
Post Edited (Kramer) : 3/30/2006 5:50:46 PM GMT
You may need a BOR26 setting on the device line.
Or as Kramer has pointed out a different OSC setting.
Bean.
"SX-Video·Module"·available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module"·available from Parallax for only·$49.95 http://www.parallax.com/detail.asp?product_id=30015
Available now! Cheap 4-digit LED display with driver IC·www.hc4led.com
"I reject your reality, and substitute my own." Mythbusters
I have to ask, how in the world did you come up with:
"Also, if you consider diodes usually have 0.7volts of voltage drop, I suspect that lower voltage ICs must stay about an absolute minimum of about 4 x 0.7volts = 2.8volts."
Nate
I have tried bith OSC1 and OSC2
other settings are:
internal feedback resistor enabled
BOROFF
TURBO
STACKX
WATCHDOG
Bean.
Thank you very much for your advice!
After changing from "BOROFF" to "BOR26", the MCU can run at low as 3.2V.
But I don't understand why the brownout level affect the operation of my programme. Can you tell me why? Thanks a lot.
Bean.
6+6=10 (Long live the duodecimal system)
