DTMFOUT and arrays
The BASIC Stamp manual has this line of code as an example:
DTMFOUT 10, [noparse][[/noparse]6, 2, 4, 8, 3, 3, 3,] 'Call Parallax
Will DTMFOUT understand the following chunk of code?
number VAR Nib(4)
... (number gets assigned a valid DTMF number)
DTMFOUT 1, [noparse][[/noparse]number]
I don't have the circuit on my board, but let's say that it's set up correctly. The syntax check tokenizes it sucessfully, but I don't trust it.
Many thanks!
number VAR Nib(4)
Many thanks!
The command works as described in the example and in your sample loop. To convince yourself that the number is being correctly assigned, just put a DEBUG command after the DTMFOUT line and watch the numbers on the debug screen.
To actually get the DTMF to dial, theres a bit of interface hardware between the stamp and the phone line. It consists of a special transformer and a couple of zener diodes. Total cost is about $10.
I've used this process to successfully let the Stamp call a numeric pager and give a code number which represented a certain alarm condition of a piece of machinery.
Cheers
My class is actually building the circuit from scratch, but we haven't been issued the hardware yet (so I can't test the code).
