I did, with the link above.· All the initial responses to that thread were regarding parallel I/O of the keypad.· Did you even read any of the messages at the link?
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
· This is a link to a datasheet for a 20-key decoder.· Don't panic -- you don't have to use all 20.· It outputs a 5-digit binary number for each key/button (it's based upon a matrix / row-column affair) along with an output that goes HI when any key is pressed (Data Available.)· The output states·latch each time.
was wondering if it was possible in someway to log the real time on each keytroke
is that possible if yes using what ? does it require hardware or programming ?
http://forums.parallax.com/showthread.php?p=570329
could someone direct me to a basic 4x4keypad
scematic using basic stamp2
thank you
http://jameco.com/wcsstore/Jameco/Products/ProdDS/44572.pdf
555 chip is that for it?
www.parallax.com/detail.asp?product_id=604-00005
www.maxim-ic.com/quick_view2.cfm/qv_pk/2688
There are code examples for interfacing with the DS1307 in the StampWorks manual (downloadable from Parallax' web site).
OS-X: because making Unix user-friendly was easier than debugging Windows
