Using a 13.56 Mhz RFID reader with BASIC Stamp
Hi all,
I'm trying to find a way to use an RFID reader that can read most common RFID tags with BASIC Stamp. Parallax's RFID reader is working on 125kHz while most common tags communicate at 13.56Mhz.
Would anyone know of an RFID reader that would connect to a BASIC Stamp in a not-too-complicated way?
Kind regards
//martin
Kind regards
//martin
Jon Williams
//martin
One is a fully configured reader assembly, including antenna, support chips, etc., and is intended to communicate with a "server" with "full voltage" serial or other means. Other than the products like the Parallax reader (and at least one clone) that read the 125 MHz tags, these things are several hundred dollars. I have not seen anything "affordable" in other frequency ranges. That doesn't mean the don't exist, just that I didn't find any.
The other end of the spectrum is "chip level" where there is an IC that will take care of driving the antenna and reading/writing the tags, but require the user to design and develop all the require support circuitry, including the antenna. I suspect this does not fall into the category of "connect to a BASIC Stamp in a not-too-complicated way?"
John R.
8 + 8 = 10
DrWass2
