programming without the board
I was wondering if I could reprogram my bs2-pe without connecting it to the proramming board, say with a serial cable?
Is it 4 pins? Sin, Sout, Vss, ATN?
thank you
thank you
·· Yes, those are the required connections and the diagram is attached.· You'll notice there are two capacitors which may or may not be needed in your application, but should probably be included anyway just in case you ever need to use a computer that does require them.
csavage@parallax.com
·· You always want a common ground when communicating between two devices.
Are there any that won't work with them?
And are there limitations on where they should be placed? Should they be placed on the circuit board near the Stamp? Or could they be wired inside the DB-9 connector shell? Or does it not matter at all?
Jon Williams
But I prefer four-pin headers, which require a custom cable, but take less space on the board. Would the caps work as required if they were soldered into the DB-9 shield at the PC end of the custom cable, instead of on the board?
Jon Williams
I've been putting a four-pin header immediately adjacent to pins 1-4 of the Stamps' sockets, and wiring them straight. With the serial ports I've been using, it's never been a problem. If I add the caps on the board, I need to connect one in serial between the header and the stamp, which wrecks the tight, simple configuration that I've been using.
I don't I've yet put a Stamp circuit on PC board that was laid out so that the caps could have been placed without significant reorganization.
Jon Williams
I could have tested it myself - except, of course, I don't have a computer with a serial port that shows the problem.
As for custom cables, if I'm using a custom connector on the board, I'm going to need a custom cable no matter what I do.
But if I ever put a standard DB-9 on a board as a programming port to the Stamp, you can be sure I'll put the caps on the board.
Jon Williams
·· The main thing the caps do is prevent the DTR line from being held HIGH by computers that do that when the port is closed.· I would recommend putting the caps right on your BASIC Stamp Board, although I don't think it matters it they're in the cable.
