I want to install a bs2 on a breadboard and use it for experiments. Searched the internet but couldn't find anything helpful. Can someone tell me how to do this? Thanks
I guess I wasn't real clear. I'm pretty new to electronics. I want to build the circuits on a breadboard·so it resembles a boe-board. I'm trying to find info on how to go about it. I think it would be a good learning experience for me. I appreciate your reply. That explains how to put the stamp on the board. I just need to know how to set everything else up so I don't fry anything. Any web sites or information will be greatly appreciated. Thanks.
· I think that you would learn a lot more by seeing and working with something done right in the first place than you will or could by struggling along, worrying and wondering,·as you've proposed.
Look at the last page of this PDF for a schematic of the Board of Education (rev C). I would highly recommend that you buy one as they are put together well and give you less headache. But if you want to test it out, here is the circuit.
·· I think the hardest part for someone not experienced in electronics would be connecting the Serial Cable and the power connections.· Especially the serial cable though because you would really need to hack one for the best results, or wire a DB9-F on the breadboard.· Still, it wouldn't be easy at all if you're totally new.· I would recommend experimenting with some lesser circuits on the breadboard first and fully study the BOE Schematic posted above.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
The Stamps' serial interface only needs four wires. Messing about with DB9's is a waste.
I picked up a 9-pin female crimp-type D-Sub connector at Radio Shack, and wired to a length of telephone cord. The other end got a four-pin header receptacle.
I just push the Stamp straight into the breadboard, and put a four-pin header into the tie-points adjacent to to the stamp pins.
P.S.· Great forum!
http://www.jameco.com/wcsstore/Jameco/Products/ProdDS/283101.pdf
Add a small breadboard for $4.95 www.parallax.com/detail.asp?product_id=700-00012 and you'll have a development board that has almost all the features of the $65 BOE.
