Connection between Basic Stamp 2 & H-BRIDGE L293
Hi
I just want to know if it is safe for my basic stamp 2 to be connected with a H-BRIDGE L293 CIRCUITRY in this way :
There is two powers : 12 VDC ( for motors ) and 9 VDC ( for basic stamp 2 )
If I connect together the " VSS "·(·basic stamp 2 groud )·pin with the "GND " ( MOTOR GROUND ) pin and if I separate the " VDD " pin and the " VCC " pin by connecting them in the right pin on H-BRIDGE L293.
I think that the way I explain it is kind of difficult to understand but the only thing I want to precise is that Is it okay if I put together the 2 ground of the 2 powers·(·12 vdc and 9 vdc ) even if the the " vdd " and " vcc " are correctly separate. I just want to make sure because I don't a lot of money and a lot of time and I don't my basic stamp 2 to burn.
Please help me
If you still don't understand my question, let me know and I'll change it.
Thank you
Please help me
Thank you
·· Perhaps posting a schematic of what you want to do would get better results.· I didn't quite understand your connections myself.
csavage@parallax.com
