Sensor signal modifier, is this possible?
Hello Everyone,
· Is it possible to create a microcontroller cirtuit that can take a sensor signal (say a MAF Mass Air·Flow Sensor - 0v to 5v as air flow increases) and output a signal that is inverted (5v to 0v as air flow increases)? Basically would like to be able to modify the signal + - throughout the operating range in order to fine tune the output. I want to replace the restrictive flap door style Air Flow Meter with a Hotwire Mass Air Meter. Someone has already developed a circuit with an Op-Amp (LM324N)·that can do this, but it has very limited adjustability. Can someone please point me in the right direction?
Rick
Rick
But if you simply need to invert the signal so 0->5 volts becomes 5->0 volts, a simple VCCS circuit built from an op amp could do that , and easily to swing 0->4.5 volts to give 5->0.5 volts.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 3/25/2006 7:42:28 PM GMT
Rick
Rick
