Ds1602
I am using the DS1602 RTC to time stamp data from an ADXL accelerometer. And I am wondering if the RTC could also be used to triggger an event at say 30 seconds.
I want to ignite a secondary rocket motor seconds into flight. So if I had a transistor connected to the 12V power supply (needed to ignite)·and A BS pin, Can the RTC be monitered to set the BS pin high after a·certin amount of time?
I'm not quite sure how this would be programed? Any suggestions?
Thanks in advance.
Thanks in advance.
Jon Williams
1. Launch
2. Clear clock registers
3. Read clock registers
4. If clock is less than 30, go back to #3
5. Start next stage
Jon Williams
