2x8 LCD Terminal AppMod pinout?
I don't see the pinout for the 2x8 LCD Terminal AppMod in the online docs. You probably don't need it, if you're just plugging it into a Parallax programming board, but I'm looking to use one on its own.
Is the pinout of the 2x10 AppMod header documented anywhere? I'm sure I could work it out, but if someone could point me to the correct doc file it'd save me time.
Jon Williams
·· If you don't have a BOE there is a picture online.· The BOE has the silkscreen and the AppMod is only supposed to plug in one way so you can go by that diagram.
csavage@parallax.com
Jon Williams
Thanks.
