RobotDlay timings
When using the RobotDlay command, inputting anything other than 50ms increments causes the timer to go about 3-4 full seconds, rather than the requested time (say, 620ms for example).
Is this normal?· Is there any fix available?
Thanks in advance.
Thanks in advance.
Jon Williams
NOTE: The attached file is actually the program before editing, but the problem is still the same.
I suspect this was originally one of the Tab Robot supplied programs. Attached is THE original I would guess.
Bruce Bates
<!--StartFragment -->
csavage@parallax.com
