enhance the current for servos
I have constructed a robotic arm, and its element at the last DOF is a pair of electromagnets which i use in order to lift objects. The problem is that the electromagnets which i drive directly through the ports consume a great deal of current, so the·servos probably do not have an adequate amount of current to work efficiently and situations, like jerking·and loosing the desirable position appear, so how can i cope with this problem and if i must use some kind of external supply, how can i develop that technic. any help would be appreciated. thanks.··
Secondly, you probably shouldn't try to drive an electro-magnet's coils directly from an I/O port.
Third, this situation is typically handled with an external "unregulated" 'wall-wart' power supply putting out 7.5 to 9 volts DC, which is then regulated with a 7805 or 2940-5 linear regulator. This will get you 1 to 1.5 amps, which usually is more than enough for several servo's.
And if its not enough, you can power the servo's with their OWN wall-wart. Just make sure all the grounds of all the powersupplies are tied together.
http://www.parallax.com/detail.asp?product_id=28023
Post Edited (neoteric) : 3/21/2006 3:53:31 PM GMT
