Look at the documentation for the Toothpick <http://www.parallax.com/detail.asp?product_id=30076>. The manufacturer has Pocket PC programs that allow you to monitor/change parameters in the Toothpick that the Stamp can also access. You can also set up a serial channel from the Stamp via Bluetooth using standard Bluetooth conventions.
