Downloading code
I am using a BS1 with serial adapter, i don't get why the code won't download it says "no BASIC stamp found" i don't get what I am doing wrong i have the ground connected to ground on battery, serial connector soldered into appropriate pins, i've done acontinuity check on all pins nothing shorts everything is connceted.
I applied power to the stamp via an 8.4 V r/c plane battery and plugged in the serial cable (checked to make sure A is opposite ground and >> is connect to ground)
is there anything i'm missing????!!?!! i also clicked the BS1 icon in the editor as well
much discussion:· http://search.parallax.com
This is a common problem, and usually requires that you set your latency on your PC serial port very low.· Lowest is 1, which is what I use.
A couple of questions....
Have you hooked ever had any stamps recognized by the PC?
Are you using a USB to serial adapter?
Do you have a Pocket PC or other Activesync software going.
PS· are you using windows?
Post Edited (neoteric) : 3/21/2006 8:21:16 PM GMT
Shawn Lowe
Remember - No matter where you go
There you are.
but one question: how do I set latency ? i am using windows
· To do this (adjusting the send & receive buffers), open Device Manager [noparse][[/noparse]Control Panel / System -- Hardware].·· Find your USB-to-serial converter in COM & LPT, click it, and then click the Advanced button, then you'll find the two slider bars.
··PS -- How about ditching that cry-baby emoticon?
· PPS -- 3 Posts since this one and Salik's participation in the problem-solving process has been less than active.
Post Edited (PJ Allen) : 3/23/2006 2:42:39 AM GMT
csavage@parallax.com
In order to comnmunicate with the Basic Stamp 1 serial adapter you have to be using the BASIC Stamp Windows Editor version 2.2.5. Earlier versions do not support the BS1 serial adapter. The fact that things work with the BSII, but not with the BS1 serial adapter would tend to indicate you might have an outdated editor..?
Vern
No prob, happy to help. I wonder if this did/would solve Salik's problem as well...?
Vern
· I use the 2.1 version of the PBASIC IDE to program BS1s all the time.· Haven't used it via a USB-to-serial though (if that's what somebody was meaning.)
· Still waiting for salik to participate in the problem-solving process.· What's the deal there?
I'm not using a USB to serial adapter, straight into the serial port, I will try what you suggested about changing speeds on the com port as soon as I get the chip back from school
' {$STAMP BS1}
' {$PBASIC 1.0}
It seems we will never get a rensposible answer from parallax stuff here.....
Well, I'm not Parallax, but, philipad23, I (and others) need to know the particulars of your set-up regarding your BS1.· Are you using a carrier board or a B-o-E and a BS1-IC or·a board of your own devise, power supply or battery, etc.
I am using serial adapter for BS1.
I have the headings
' {$STAMP BS1}
' {$PBASIC 1.0}
and the BS1 is connected to serial adapter as shown on·its datasheet...
Am·I missing something?
Bunk!!!
