Temperature control
Hi there,
I need to control the temperature of an electric heater.
The temperature must change over time.
I think this should be possible using the BASIC Stamp but I never worked with it and I don't know where to begin and what parts I need for this application.
Hope someone can help.
Externally, what you would need would be an appropriately sized solid state relay (SSR) to control the heater, and you will use a Stamp pin port to drive it (ON and OFF). Yhen you will need a temperature sensing element. There are a number of thermostat IC's available, and one of the ones often used with the PBASIC Stamp is the Maxim/Dallas DS-1620/1621 although there are dozens from which to choose:
http://para.maxim-ic.com/cache/en/results/5120.html
The Stamp will continually poll the temperature/thermostat IC to see when to turn the SSR ON or OFF. There isn't a whole lot more to it, if that's the limit of what you need to do. If necessary, the temperature section of the thermostat can be queried on a regular basis, to ensure that freezing isn't about to occur, which might happen with a faulty heater, or blown line voltage fuse/breaker.
Bruce Bates
<!--StartFragment -->
Post Edited (Bruce Bates) : 3/20/2006 10:56:36 AM GMT
csavage@parallax.com
I have to control the temperature in an temper oven for curing fiberglas. The maximum will be 60°C. The temperature has to rise from room temp to the maximum at about 2 degrees per hour. I think an IC thermostat will be fine. Would be nice to check the temperature at more than one spot.
Regards
Hans
·· Actually at 60C I think you're going to need a probe.· That's 212F.
100°C ==> 212°F
60°C ==> 140°F
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
·· Somehow I misread my trusty CONVERT.EXE program...Ah well...Yes, then it could work!·
