MMC Serial Mode, dumb question
Guys, I have a serious amateur question here about the serial connection on the MotorMindC. Pins 20 and 21 are TX, RX respectively. The DB9 Connection goes like this, correct?
DB9=>MMC
2 => 20
3 => 21
Luke
The perversity of nature is nowhere better demonstrated by the fact that, when
exposed to the same atmosphere, bread becomes hard while crackers become soft.
DB9=>MMC
2 => 20
3 => 21
Luke
If I'm reading what you're saying correctly, NO. When connecting from an RS-232 "sender" to an RS-232 "receiver", Tx ==> Rx and Rx ==> Tx, so:
/code
DB-9·············· MMC
·2 (Tx)· ==>· 21 (Rx)
·3 (Rx)· <==· 20 (Tx)
code/
Bruce Bates
<!--StartFragment -->
I thought the DB-9 was this:
2 => Rx
3 => Tx
http://www.zytrax.com/tech/layer_1/cables/tech_rs232.htm#db9
Luke
My SINCERE apologies. I glanced up at my RS-232 "cheat sheet" and I thought I was looking at the DB-9 column, but I was looking at the DB-25 column. You are INDEED CORRECT!
I think I'm going to make up two different "cheat sheets" since this isn't the first time this has happened - sorry.
Bruce Bates
That's Ok! I had to go to the cheat sheet to figure that out as well. I've been known to make many of the same blunders, which is why I ask these dumb questions.
Thank you for your help.
Luke
