Button
hi,
I have a BS2Pe and using push-buttons I want the microcontroller to log the entry
This is how I wanted to monitor each button.
Nomally if I dont press any button it should keep looping forever right?... but it doesnt. for some reason some of the buttons think they are pressed and execute the concequent code
I'm starting to doubt that maybe this is not the best way of using the BUTTON command?
any ideas?
any ideas?
check0: offset = 0 BUTTON bu0, 0, 255, 20, b0ws, 0, check1 offset = 0 RETURN check1: BUTTON bu1, 0, 255, 20, b1ws, 0, check2 offset = 1 RETURN check2: BUTTON bu2, 0, 255, 20, b2ws, 0, check3 offset = 2 RETURN check3: BUTTON bu3, 0, 255, 20, b3ws, 0, check4 offset = 3 RETURN check4: BUTTON bu4, 0, 255, 20, b4ws, 0, check5 offset = 4 RETURN check5: BUTTON bu5, 0, 255, 20, b5ws, 0, check6 offset = 5 RETURN check6: BUTTON bu6, 0, 255, 20, b6ws, 0, check7 offset = 6 RETURN check7: BUTTON bu7, 0, 255, 20, b7ws, 0, check8 offset = 7 RETURN check8: BUTTON bu8, 0, 255, 20, b8ws, 0, check9 offset = 8 RETURN check9: BUTTON bu9, 0, 255, 20, b9ws, 0, check10 offset = 9 RETURN check10: BUTTON bu_ok, 0, 255, 20, b10ws, 0, check11 offset = 10 isSer = isSer + 1 IF(isSer = 3) THEN GOTO SerialControl ELSE GOTO here ENDIF RETURN check11: BUTTON bu_clr, 0, 255, 20, b11ws, 0, check12 GOTO Main offset = 11 RETURN check12: BUTTON bu_can, 0, 255, 20, b12ws, 0, check0 offset = 12 GOTO Main RETURN
csavage@parallax.com
Thank you for the quick reply
Here is my complete code.
Basically the code takes in the entries from the user (8digits) and stores them to EEPROM
my other concern is that my 8-digits entries are 32 bits each which means I wont be able to store that much in my EEPROM
Cheers,
My other question is how can I add more memory in odrer to be able to store more entries on the EEPROM?
Should I use registers? or uMMC controllers?
One more little question: do you think this is a good algorithm to log entries? my concern was that maybe my algorithm uses too much space.
Thank you for your help
·· I did not analyze how you were storing data.· Just the original issue regarding the inputs.
Jon Williams
