Standard servo connector.
I see now that my standard servo connector does not fit into
the Board Of Educations servo port.· Should I modify it, or just
put some headers on the development board and let that be that.·
Thanks guys!
From···· ·Northwest· ·· Indiana-
Where·· the · introverts · stare
at··· there·· ·shoes··· and·· the
extroverts stare at your shoes!
Thanks guys!
I'd have to suspect that you're not using Futaba servos? If that's the case, you may want to purchase a few Futaba servo extensions, and a few servo extensions for the type that you're using, and make up a batch of adapter cords. That's probably the easiest way to address the problem. If you need a source, just shout.
I don't have a BOE board, so I'm just presuming they have a Futaba plug configuration. I'm sure someone will correct this thought, if I'm wrong.
Bruce Bates
<!--StartFragment -->
