Help with photoresistors
'm trying to send power from some AA batteries through a photoresistor and drive a motor. The motors drive when I replace the photoresistor with a wire, but no with the photoresistor. I have replaced the photoresistor many times with different kinds of photoresistors but no luck. What is wrong???
· A photoresistor will go "low ohms" in presence of light (daylight), but not to 0ohms.· Another matter is that photoresistors are not for running current through, like a switch, being typically 1/8W or 1/16W devices.
· What you want to do is use it/them as part of a voltage divider and sense the voltage across it.
· I am providing two experimental circuits, if you are interested in learning.· One is just a basic divider and the other is for use with a STAMP by using RCTIME.
Post Edited (PJ Allen) : 3/18/2006 2:35:13 PM GMT
Hope I'm clear.
· OK, boe-bot, you have a good time.
· If you're trying to use the "photoresistor" in series with a motor to slow it down, then you go right ahead.· Who am I to stand in the way of such genius?
· Hope I'm clear.
