sharing the crystal
Hey folks,
Does anyone know if I can "tap" the same 75MHz TTL crystal to the SX for other ICs in my circuit? Are there any special restrictions, problems or results with this?
Given the (sometimes) fussiness of getting crystals to start up, especially at high frequencies like 75 MHz, I would think that buffering the oscillator circuit beofre passing it out to the chips in your circuit would be a good idea.
Thanks, PeterM
I have a post - "oscillator considerations" - which raises the same question. Solutions I have been looking at include using a clock distribution IC which buffers a clock source and splits it into many channels. Pericom, Analog Devices, TI and other manufacturers make them. They are very specific however in what they will accept as a source and output specification (xtal, lvpecl, lvds etc...). I am looking for one that will work at TTL level and cover the SX operating range 4-100MHz. When I find something Ill let you know.
Andrew
TI makes a line of clock distribution controllers that will output up to 8 TTL compatible clock signals. They all begin with the prefix CDC (clock distribution controller), and can be found on their product search page. Also, the outputs can be put in a high-Z state via a select line so the clock will not interfere with in circuit programmabillity of your SX.
Post Edited (BebopALot) : 3/19/2006 9:25:46 PM GMT
Make sure you physically test the "Hi-Z won't interfere with SX programming" asumption before you make any PCBs. I made this assumption using TTL oscillators only to find out they have diodes in their output path which end up clamping the protgramming voltage generated by the SX-Key so that it can't program chips. I learned this after I made PCBs.
Thanks, PeterM
