Looking for component to measure tyre pressure
Hello,
did somebody tried an application like that, interfacing wireless receiver for tyre pressure with a Basic Stamp ?
Which wireless component(s) could do the job ?
I've looked the net with google but there's a huge bunch of informations but none is usable and apart papers about how it works or how it should work, i've found nothing else that complies with the design i want.
Wireless sensors not located in valves but inside the rims.
JohnnyB
- Stephen
-phar
Well all this is very confusing, there are so many things around TPMS but no datasheets, the only schematic diagram i found is this one.
and here some informations about a batteryless sensors that sticks inside rims.
www.edn.com/article/CA421537.html#SAW%20sensors%20enable%20batteryless%20TPMS
All this is very attractive but no way to find out where to buy, the Corvette systems and as many other cars are using complete valves systems with battery embedded in a little plastic or rubber case but they do not last so much time and they have a side effect, they do modify the wheel balance...not important for an ordinary car with normal use but for a car running on tracks, even at amateur level, this changes a lot, so that's why a sticked chip (it looks like a tiny stamp) on the center of the rim is better choice.
well ok after searching i think, if i understand right what is said in this document, the chips i'm trying to find would cost around 7 Euro.
www.newtech-ibs.com/neuf/frames/articles/racetech_08_01.html
i'll try to get in touch with them if they just don't drop my mail in trash as i'm not professionnal
see: http://www.uspto.gov/patft/
download the tiff imager. Search on tire presure sensor.
The explanations in the patents will show many ways to actively or passively transmit from inside a tire.
It sure is however a great way to come up to speed on ANY technology.
Thanks anyway.
