Debug problem with character display
I am having a problem with displaying a character that I change in my program using Debug.
I define·several variables to be a Byte and then I assign them either "+" or "-" or "X" or "Y".· When I use the command, "Debug STR ? VariableName" , it returns the value as the first character, but adds a lot of garbage to the output line.· If I output the ASCII value, it is correct.· Why is Debug adding all the garbage to the output?
You are causing the "garbage" to appear by use of the "?" sub-parameter. Try removing it so that all you have is: Debug STR VariableName
Bruce Bates
<!--StartFragment -->
