5v - 24 vac Relay for Ventilation Controller Project?
I have a project idea to build a ventilation controller for a residential furnace system.
This controller would open/close a 24vac motorized damper to allow/disallow outside air into the return duct of a forced air furnace system.
I would like to avoid actually powering the motor with the basic stamp, so I have a 120VAC/24VAC transformer.
My question is, do they make a relay that can be energized with a 5v signal·from the Basic Stamp 2 that will simply close the circuit to allow the 24vac through to the motor?
If not, would I need to provide a resistor,transistor,diode and then relay to bump up to a higher voltage (24vac) to control the motor.
If the latter, then I suppose I can eliminate the transformer and just power through the basic stamp.
Any input would be appreciated. See attached diagram for my proposed circuit to connect to the damper.
Jon Williams
If I didn't have the transformer and therefore alternate power supply, could I use this relay to "bump up" the basic stamp output to power my load?
Sorry, haven't done much besides low voltage DC control.
Jon Williams
Could that SSR be used to replace an SCR in some cases...where the SCR simply functions as a switch?
Do you know what frequency it can handle?
JohnnyB
Jon Williams
JohnnyB
