demo board design input
I realize you guys have pretty full plates to deal with on a number of issues, but if the demo board is being redesigned, this may a thought worth going back to. As just a simple idea, if you want to free up some real estate on the demo board, why not eliminate the db9 serial connector ? Go with usb, and since there is going to be a usb port anyway, it could see double duty for programming or peripheral, by means of a switch. Unless someone is using a very old computer, they should have a usb port. And, a possibility is to add a usb to serial adapter with the demo board package( at a reasonable cost ), if someone really requires it . I know the serial port interface has been a standard for many years, but it may be time to put it in the past. And another thing i would like to see is the power switch setup changed to a right angle, facing to the outside of the board , so it is easier to find and use. And for the just dreaming part, interchangable breadboard area. Two headers on each side of the board, that a breadboard could be " plugged " into, saving time and possible damage of components by redoing circuits. And a plugin solderable proto board could be used instead also. Yeah, i know, expense is a big issue, but what the hay, never hurts to make a suggestion.
kelvin
kelvin
Jon Williams
·1+1=10
